Looking for recommended Rear window zipper pulls..I've broken probably 4 at this point. I need a pull with a little more length to it if possible because those corners up at the top are killing me =)
:Thanx:
GOT DOORS?
With one arm, pull down on the top to release some pressure. Also, attach the bar and those 2 "tabs" (whatever they are) at the bottom after doing the zipper.
I folded back my freedom top, undid the windows, unhooked the sail panels and then put the window in. Then I hooked hooked the freedom top back up (don't clamp), put the sail panels in and then clamped the freedom top in.
Sent from my SM-G930V using Tapatalk
