I just picked up a factory hardtop a could of days ago. After putting it on the Jeep, I notice it is REALLY loud above 40mph or so. Previously the Jeep has only had a softtop.
Here is the question, is there a different gasket for the top of the winshield for hardtops v softtops? I was told it is the same by one person and there is no gasket by another.
Previously I've had a YJ and CJ... this wasn't an issue there.
i have a '02 Sahara that came with the factory duel-top option and both tops use the same gasket/seal at the top of the windshield. If your hardtop is making a lot of wind noise in that area the top might not be installed correctly at the windshield junction or maybe that seal is gone/degraded.
Where the top latches to the front try adding a small piece of sheet metal to the grove where it latches into the top. sometimes 1/8 of an inch in the grove of the top will make a huge differance. I just bent a small piece and laid it in the grove and it helped.
Mud
I rolled up a little duct tape and put it on the end of the hook holding the top down onto the windshield frame... killed the vast majority of the wind noise.
autozone has some generic weather stripping, it works really well. I padded mine and its super quiet
they also have a topper / camper weather strip stuff that you put around the tub, its very nice
