1 - 10 of 10 Posts
so, i have a huge hole in my gas tank and the only way to fix it is to replace it... does anyone have instructions on how to drop the fuel tank? and will the original sending unit (which if fine, hopefully) be usable on an aftermarket tank? thanks dudes
Mine YJ was 4 bolts rear bumper, 4 bolts thru crossmember, disconnect 3 rubber lines and fish it out. Just be careful with fuel lines. I snapped off one of the tubes going into top of sending unit. Check boneyard or eBay. Many used available.
Hacks off Parts while Lit
i got mine off jcwhitney iirc. it was direct fit and existing fuel pump etc worked. only gripe is there are no baffles (i think there are in stock tank but not sure) dont recall the price, but i wanna say it was 200 or less. my stocker had a leak from the skid plate bashing it and rubbing. new one is plastic of some type.
I have an extra one in the garage if you want it. it's got a booger on the passenger front side where the exhaust tried to melt it. It's solid with no holes though. It would last for a few years as long as the exhaust isn't shooting on it. Pm me if you want it
Have you tried eBay? I've seen several out there. Also do a google for "yj gas tank on craigslist". This will show results across the country. That is how I found my fuel sending unit for $40 shipped to house. I live in Ohio it came from Maryland.
1 - 10 of 10 Posts
