1 - 11 of 11 Posts
The rear is STAMPED
DANA
43225
022 1
REV K
02 27 97
The front is stamped
DANA
40869 1
RVS
110895
and are they worth a crap. Light to moderate 4 wheeling, no rock crawls
2001 Wrangler Sport 4.0L Auto
Thank you guys you are a lot more knowledgeable than I am
I'm not going to Google your numbers since you could easily just do that yourself but 99% chance you have a Dana 30 front and a Dana 35 rear and yes they're absolutely fine for moderate wheeling with up to 33" tires
front is a low pinion dana 30, rear is a dana 35.
There should be a tag on the axle that will tell you gear ratio.
you should be fine for light wheeling with moderate tire sizes.
There is a tag on the differential with several numbers on it. Which one will tell me what the gear ratio is?
1 - 11 of 11 Posts
