Dumb question. When I have the stalk set to auto, sometimes I’ll bump the stalk pushing in the fog toggle (using turn signal). Is there a part I can buy that forces the fog toggle extended? I can surely jerruh rig something, but I’m sure I’m not the first.
Could you maybe put a zip in the small space created when you have it extended out? That or some sort of plastic I'm sure would work in between it but a zip tie is the first thing that comes to mind.
Even a rubber band would probably do the trick.
Yeah. I kind of figured the only solutions were workarounds.
Thanks. I’ll just use a zip tie for now. Might see if a friend will 3d print something that looks more oem.
Thanks.
Rubber O-ring. You can easily roll it out of the slot if you choose to manually operate the lights. I did this on my wife's Rubi as she would always bump the end and turn them off.
