The black end is supposed to go into the new stereo, and the two larger ends are supposed to go into the stock jeep harness that was orininally conected to the stock stereo. Are you simply replacing the stereo?
Well heres the problem it seem the person who i had bought the jeep from had cut them off to put in his own system and he used butt connectors to put wire togethor for his system. So can u tell me where are the wire lead then I can easly connect new wires for new plug with butt connectors and just do the same as he did xD
Question Answered. Thread Closed.
I found all the jeep wire colors which allowed me to figure out which color went with the sony colors. so now i will just use butt connectors to link the wires and should it sound work. I will give you an update tomorrow. if u want the color code i will post it below.
Constant 12V+ Pink/White
Switched 12V+ Pink
Ground Vehicle Chassis
Illumination Orange
Dimmer Black/Yellow
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Brown/Red
Left Front (-) Green
Right Front (+) Blue
Right Front (-) Purple
Rear Speakers 5 1/4" Roll Bar
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Blue
Right Rear (+) Blue/White
Right Rear (-) Blue/Red
