I have a 06 Wrangler X with the 4 speaker stereo system(Really bad).Has anyone added the six speaker sound bar?Is it an easy install?
Like others said... just upgrade your front and sound bar speakers and you will be pleased.... I just did that some time ago...I have a 06 Wrangler X with the 4 speaker stereo system(Really bad).Has anyone added the six speaker sound bar?Is it an easy install?
The 06 overhead speakers are a different design then the older TJs. the newer ones are enclosed in a 'pod' design so you can remove them if you wanted too. That design is basicly what you're talking about doing by blocking the chamber that runs the lenght between the older overhead speakers.The foam does make a difference. For my sound bar i used 3/4" thick pool filter foam that fit good inside the bar. It does make the bass a bit softer and louder.
