The other morning it was about 20 degrees and when I started my car it sounded like the belt was loose and making an incredibly loud shrieking noise. I thought it might have something to do with the cold temp however now it does it every now and then. Should I replace my belt or do I need to check something else out?
Had the same thing happen to me. Not sure what it was....having my mechanic look at it. Could be a loose belt, or the tensioner
any possibility you have a small coolant leak and a bit is getting on the belt?
if its a tensioner it probably wouldn't be intermittent
Kuda0005 will you let me know what your mechanic says? I appreciate the feedback
Will do. What's weird is that the noise goes away over time (when Cappy is all warmed up).
Yeah....Cappy....my son named him for Captain America. We will be putting the shield on the wheel cover on the rear of the jeep.
Likely the belt needs to be a smidge tighter. If you have a spring tensioner, you may just need to replace the belt.
Same thing happened to me. I replaced the belt and tensioner. Didn't help. So I WD-40'd the alternator and it quit. I'm keeping a leery eye on things but so far....
