Any body have a brand name for spacers for a 2008 wrangler sahara. Not looking to break the bank just yet> just trying to slowly add different things. Also if i add spacers which i think i want to go with the 1 1/2 inch, would BF Goodrich 285/75r17 fit. having a hard time finding a bigger tire than the stock dueller that is on my stock rim right now
Spydertrax is of good quality and 1.5" wheel spacers will be fine for a 285 wide tire. You may want to consider a small lift or leveling kit if you are going to run 285/75/17 as they are considered a 34" tire (285/70/17's are 33's) so you are going to get fender rubbing especially if off road and disconnected. Even a 285/70/17 will rub if disconnected and flexing without a small lift so that will give you some idea.
