I am not talking about the 3rd brake light.
on my 98 tj, I tried to mount my spare (OEM RIM) with the new 31 tire on it but it doesn't fit. I end up removing the rubber stop (4 of them) and then added washer on the 3 "bolts" that hold the rim in place. for some reason I dont like it.
should I put spacers between the mount and the tail gate and cut some of the rubber stop to make it fit?
how did you guys do it ?
I had the exact same problem. I had a 31 put on mine. I just removed the rubber spacers and said that Be fine. I haven't had a problem with it.
your tire doesn't touch the hinges ? mine were, thats why I added the spacers. now I have about 1/2 " gap between the gate and tire. but I'm kind of worry that the vibrations, after a while, would put too much stress on the mount and / or gate
I'm guessing you put 31"s on stock rims. My 31" fit great, no mods needed. But that is likely because I have 4" backspace on Soft 8 wheels.
Stock wheels have more backspace (5.5 I think), so the wider, not necessarily taller tire is eating up extra space.
FWIW Soft 8s are made in the USA. You can get 15x8s from Jegs for under $50 each shipped to your door. This will help with clearance while turning also. Not to mention look good.
thx for the info, the soft 8 are on the whish list but it would be way after xmass.....
