1 - 11 of 11 Posts
Does anyone know of a video on how to change spark plugs for a TJ? I've changed them before in a Honda Civic, but there are things I have to take off to get to these and I am not sure how.
Any advice or video would be welcome.
Paul
if there is a bar over the 6 plugs, there are a few bolts,4-6, to take out that go through it. pull as straight up as you can. lay it off to the side, and replace the plugs. make sure they are gapped right washerless plugs, snug them, then add 1/16 turn
washered plugs, tighten them and add 1/8 turn
Knows a couple things...
Champion's 7034 is a great choice. If they don't have that one in stock, Autolite's APP985 (not AP985) would be a good choice too which is pretty much the same plug as the Champion 7034..
Im gonna be changing my plugs also, what is the gap supposed to be on the champions? Im assuming my 4.0 is missing when u first start it and goes away when it warms up some?
The usual gap is .035 though some Owner's Manuals for newer TJ 4.0L engines specify .040. Your Owner's Manual will give the spec, and there is usually a sticker specifying the recommended gap inside the engine compartment.
1 - 11 of 11 Posts
