HiYa, all....
I got ignition coil or spark plug static wafting thru the stereo. I have a good ground to the unit. Is there some type of noise cancellation device that I need to add? It's definitely spark /coil noise. The sound raises with the revs of the engine..... :Thanx:
Knows a couple things...
Did anyone install non-resistor spark plugs or so-called "performance" low resistance ignition wiring? Low resistance ignition wiring adds literally no performance... what it does add is ignition noise and static.
