1 - 9 of 9 Posts
Just changed all of the plugs with the Champion 7034's. Now, I am getting code P0306. Can someone give me some advice on what to do now? The jeep is running a little rough and now occasionally makes ticking noises with a long pause in between.
Any ideas?
Knows a couple things...
If it's a distributorless ignition system make sure all the boots are over the spark plugs. It's easy to have one boot miss the plug which has happened to me. Otherwise check your spark plug boots to make sure they're properly seated
I'm not an expert, but I went threw this. Clear the code. Assuming you have a coil rail, take it off and make sure you didn't damage a new plug. Personally I missed a plug when I re-installed the rail. Not once, but twice :banghead:
Definitely sounds like something isn't seated right or a faulty spark plug was installed.
1 - 9 of 9 Posts
