Not sure if this is where I should post this or not but I took my doors off the JKU and while driving down the road the driver side front speakers go out. I can hear the sound shift from left to the right speakers. It stated yesterday morning and happened a few times yesterday as well as a few times today. Only thing I can think of that was different from everyday driving was I had the doors off. I will be putting the doors back on tomorrow b/c of weather, but will be listening to see if they will do it with doors on or not. Has anyone experienced this before and know a fix? I have checked connections and made sure everything was plugged in and not disconnecting and couldn't find anything. Thanks for any advice or input.
If the speaker cone is made of paper, and you got it wet, while washing the car with the doors off, this might cause the problem. The night dew may have got the cones wet too, with the doors off. A closed vehicle would protect them, but not open doors, especially if the vehicle is outside at night with the doors off. Once you get paper cone speakers wet, they are toast. They don't last long regardless anyway. It sounds to me like you have paper cone speakers.
Are you sure the sound is switching from one side to the other? An intermittent fault in one of the speakers might create that effect - to be certain, I'd start by using the fade and balance controls to focus all of the sound on a single speaker for a few minutes and see whether sound is constant in volume and quality, then do the same with each speaker in turn. If one speaker is intermittent, then you've found the culprit. If all speakers are constant, or if all speakers are intermittent, then I'd be more inclined to think the fault lies in your head unit.
My soundbar passenger side was doing a buzz/humming and it was driving me nuts, so finally after a month I called the dealership. They said they would replace it and set an appt., but then called me back and said Chrysler has it on a recall for the 'amp' and told them that needs to be replaced not the speaker. I changed HU from the 130 to the 430N and I'm not going back. I just don't know why it started buzzing out of the blue when it hadn't when the HU was changed. ugh!
Yeah I ended up taking the speaker out and replacing the wires that were run to it. Haven't had a problem since. I think something was just causing it to lose signal. Thanks for all the suggestions and tips.
Well, I went into the dealership and their mechanic said if I take off my SpiderWebShade the speakers won't hum or buzz. WTF! I asked him if he was serious and he said yes. I asked for the manager, he checked and said he was ordering 2 new speakers. The dealership in my town is so small, so when I bought my Jeep I drove 100 miles to get it. I figured since they were bigger they would know more. OMG! I made a mistake.... I should of went just here in town.
