I have a 1995 yj with a 4.0, 5 speed
The tack wasn’t working, so I replace the the gauges with a used one. The tack is working however the speedometer isn’t. So I have replace the speed sensor on the transfer case from rock auto.
So I tested the voltage and the white/ orange wire has 4.9 volts and the orange wire has 7.4. So I’m at a loss not sure what to do next? Thanks Joey
Mine was not working as well. Replace my vss and nothing. Then I learned how to clock the tcase. Since you replaced your tcase, double check that you're clocked correctly.
I replaced my transfer case sensor with a cheap hall effect sensor from mouser works fine. I think it was less than 20 dollars of i remember correctly. Finding the receipt could be chore.
