Good question... I just switched mine out and they were pretty much the same size, just different number of teeth. Where'd you get it?
From ebay, here is the auction number.... 390487830930Good question... I just switched mine out and they were pretty much the same size, just different number of teeth. Where'd you get it?
Ya, I see that you actually have to twist the sensor to a position like in this photo 32-38 tooth. I think this is the right size and how the smaller gear is lined upThe differences are teeth, and the length of your assembly.
I believe you have a gear you can use; but I could not tell you if it is the right number of teeth if that is what you are asking.
It depends on what your gear ratio is too.
If stock, then you are probably good, mine has the 4.10 and 33" tires and with that gear it was only off about 1mph per my gps.
