Speedometer not working
2411 11
I have a 95 yj, I bought it with the speedometer not working. I tried changing the speed sensor. Checked the voltage at the speed sensor and its there. I bought a used cluster and replaced that and it still doesn't work, unless the new used cluster is bad. Any ideas?
1 - 12 of 12 Posts
I would say that its in the circuit board on the back side of the speedo. Maybe do a continuity test on the wiring harness from the t-case to the dash.
The circuit board is a very sensitive, POS, that was a bad idea from day one. And expensive to replace as well. If the light doesnt work either, and you have deciphered that it isnt just a bad bulb, then perhaps it might be a bad ground to the circuit board.
Thanks ill check that, I thought for sure it was the gauge cluster until I installed the new one and it did exactly what the old one did. I found it very odd that all the lights work except the speedometer light even with the new used speedometer. What's the chances of buying another bad speedometer. LOl
The last time Crash98 posted was in Aug 2014. He may not see your post. It'd be better to start a new thread describing all your symptoms and everything you've done to try to cure your issue.
Good Luck, L.M.
1 - 12 of 12 Posts
