I have 2004 Wrangler Rubicon, 5-speed Manual with 4.0. On several different occasions I have had the speedometer register over 100mph before I could get to 3rd gear - prob going 20mph. All the other gauges in the cluster were operating fine. I bought the rig salvaged from front axle damage. the original cluster was swapped out as the seller said the odometer would not display. When I put the cluster in, I had this problem. I was told it was a cluster problem, so I bought one on-line, installed it and all was well for about 800 miles, then all gauges fine except the speedometer - which is way over reading the speed. Well, I bought another cluster and same problem. My mechanic said mostly likely the vehicle speed sensor, but none to be found for 3 to 5 days.
I am headed to the Moab Easter Jeep Safari tomorrow with Wrangler in tow. Will be picking up a speed sensor that a dealer in Denver has in stock.
What are the odds that this will correct my problem? I'd really like to drive my Jeep on the trails, after spending the better part of a year working out the bugs!
Thanks for any help!
