Was it working prior to new sensor/cluster?done nothing at all just replaced the sensor and cluster. THought it might be a crimped wire somewhere somehow.
I would say then to replace the speedo gear in the TCase and see what that does. It's on the top of the rear case half and is held in by a little bracket with one bold. You can't miss it.never has worked since i have gotten the yj. all out of ideas
Are you sure the sensor is mounted in the t-case with the correct orientation? There are three rotational 'positions', each for a different speedo tooth count range.1993 wrangler, speedometer not working at all. changed out speed sensor, and cluster, cannot locate problem. any ideas![]()
