What is the brass/copper threaded piece for in this spicer ball joint kit? And also is it only certain brands that come with a locking clip ring? Thanks.
Ooh i just learned about those. Those are alignment sleeves to adjust caster/camber on other axles.
That is incorrect. The threaded insert has no affect on any alignment parameter. Which is a good thing, because it would be real hard to access once installed; you would have to separate the ball joints to get to it.
