1 - 12 of 12 Posts
2013 JKU w/ 100k Kilometers on the clock.
Dana 44 rear with Factory LSD.
When I brought it home, I tested out the LSD diff by jacking up the jeep, and spinning one rear tire. The other on stayed still. So I assumed that the build sheet was incorrect, and the jeep did not actually have a factory LSD.
15,000 km later, I hear noise. Bad noise.
Drop the gear oil...
https://www.wranglerforum.com/attachment.php?attachmentid=4191985&stc=1&d=1577226031
https://www.wranglerforum.com/attachment.php?attachmentid=4191987&stc=1&d=1577226031
So merry Fing christmas I wasnt expecting.
https://www.wranglerforum.com/attachment.php?attachmentid=4191989&stc=1&d=1577226176
I think I'll be going back to Toyota sooner than expected.
I had the same issue with factory LSD in my 2014. Less than 20,000. No noise but found when I was going to regear. Still under warranty at the time. I opted to upgrade on my dime as so many folks have had issues with spider gears in the OEM LSDs. Merry Christmas!
Mine went bad, I think, and killed my Yukon 4.56 gears at approx 40,000 miles. I think the installers missed it when replacing the ring and pinion gears for me as I found more chunks a few thousand later and it was for sure the spiders. Luckily it did not destroy the ring and pinion. Replaced with a Tru-Trac. I should have done the Tru-Trac with original ring and pinion update.
I’ve read a lot of spider gear destruction posts.
I swapped out the Trac-lok for a Truetrac last weekend @21k miles. Oil was very black, spiders were warn but the Trac-lok was still functional. Read so many stories about failure, I changed it to be safe trouble later.
Does your '13 have an automatic or manual? I really wanted a Detroit locker, but apparently it will cause the automatic transmission to go to a limp mode.
Merry christmas. Ill be honest, I was a little salty when I wrote that post. I don't beat on my rig, just light off roading.
Spider gears on my 2015 open diff. I opted for a regear.
Sent from my SM-G950W using Tapatalk
Dang, I thought it was just the LSD diffs that had the issues.
I bought my JK with 85XXX km's on it. When I brought it home, I tested to see if it indeed had LSD by jacking it up and spinning one tire. The other one stayed still. I thought the window sticker was incorrect. Turns out, the clutches were already pooched and taking out my spiders, silently :rip:
My '13 is manual, and my wife sometimes drives the jeep, we live in northern climate (icy roads in winter)
So, I didn't want a lunchbox or detroit in it. I believe this is an aggressive LSD diff, but still slips for street use.
As soon as I went online checking for issues... yep, I found a lot of spider gear problems sadly.
My friend has a '12 2 Door, and beats his like it owes him money. Not a problem in the world with his. Some of us must have had bad luck with the heat treating/LSD clutches breaking apart
Cheers
The box picture was trickery. The side facing the camera said "grizzly locker" but the other side had a part number for a Dura Grip.
Didn't see the Dura Grip part number till just now.
[/QUOTE]
Didn't see the Dura Grip part number till just now.[/QUOTE]
Ah yes, I was wondering why the box has that on there. Just an advertisement or they use the box for both centres, then chuck a corresponding part number on it.
I hope this is the last of the larger breakages. I can handle an axle shaft... but this was pricy. It’s not like I wheel in Moab 😪
$500 will get you a TrueTrac mechanical LSD. Around $400 can get you a PowerTrax GripPro mechanical LSD. Either one won't have spider gears in it that could fail.
I bought the Yukon duragrip $580 CAD.
Also doing the carrier bearings, as removing them from the stock carrier would be a pain, and there was metal floating around anyways. All in, with shipping was $800
I hope that works out for you. The DuraGrip is a clutch style LSD as I understand it, much like the factory LSD. It probably uses spider gears.
Discussion Starter · #12 ·
Thanks. Yes, it has spiders, with spring preloads. I do wish I had the extra cash to do an e locker instead, but this will have to do. Luckily this centre is rebuildable, as opposed to the factory unit, which you cannot get parts for (as I’m told from 2 dealerships and a rear end shop)
I just took the rear end and axle shafts apart this evening. Cleaned everything up, and will install the new centre in the morning.
Fingers crossed!
1 - 12 of 12 Posts
