1 - 14 of 14 Posts
Ok you need any parts other than the actual 80 dollar top? Or is it just string it up and your set
Administrator
2020 Jeep Gladiator
If TJ shades are the same as JKs then everything is included. You get the shade and the "spider balls" (bungee straps with ball ends). The straps are pretty tough but if you need to get a replacement they sell them and I have also seen them at Harbor Freight.
Yes they fit over padding. Some of the Best money you'll spend on your jeep. Solid product from a US company
x2
Only down side is didn't come with a clear picture or instructions how to put it on. But I figured it out eventually and it's going to stay on indefinitely since you can fit a hard/soft top over it. :)
Definitely beats fooling around with the header attachment with other bikini tops
I got a shadecage and it is awesome. With some research I also found a 10% off discount code.
Love mine, I have had two. Easy to install and can stay on year around under either hard or soft tops.
J
Discussion Starter · #12 ·
Do any of y'all have a discount code or know of one I could use??
Also thank you guys for all the help
I put mine on backwards the first time and was not impressed with how wrinkly it was. Then I realized the logo goes on the back and the center hole goes to the windshield loop. It was nice and tight after that.
1 - 14 of 14 Posts
