Got my sPod in this week and hooking it up today. Installation was a breeze, however, its not working right :(
When I take the low voltage fuse out it works perfectly, when I put the fuse back in...no go. I have restarted also with no luck.
Thoughts?
Is it possible your battery is bad? Did you try while vehicle is running? I know when I put mine on I tried turning the lights on before starting it and it didn't work. After staring everything has worked since then.
Have you tried a meter on the Spod do see if it was getting the full voltage? possibly a bad connection at the battery?
New battery and doesnt matter running or not they dont light up with the fuse in.
Havent tried a metter, where should I test it at?
In the source box, you have the incoming battery voltage leads. without the engine running, mine is reading 12.3 and running mine is 14.6.
