Some parts, particularly the parts made offshore, are faulty right out of the box.
What I would try is a KNOWN GOOD ignition switch. Do you have any Jeeper buddys that might loan you their switch to try?
You mention the coil might be important. Did the same problem occur with the Accel coil?
You may have a bad Ignition Control Module. Before I bought an ICM, I would buy a HEI if you don't have emissions testing where you are, or you if you think can get the HEI past the inspectors.
Check the Factory Service Manual to see if there is a test for the ICM (the module hidden down below your windshield washer bottle).
Other posters may have more input.
Good Luck, L.M.
Good Luck, L.M.
