1 - 13 of 13 Posts
I wanna hear the pros and cons from everyone about spray in liner to replace carpet...
A good friend of mine did it, it looks amazing, and is easy to clean. As soon as i have a weekend where i know i'm not going to use my jeep, i'm going to rip out my carpet and put the liner in. He used Herculiner, i think its about 60-80 bucks, and one thing of it is enough to do the tub of the jeep. He simply rolled it on, and honestly, it looks amazing.
You will get better results with the professional spray in. I know it is more expensive, but it is worth it. The do it yourself ones tend to chip very easily. I have talked to several in our club that have done it, and they all wish they had had it done professionally. I am not trying to take anything away from the ones that have done their own liners, but they will not hold up as well. I will have to admit that either way is better than nothing at all. It does help keep the heat level down, and makes clean up a lot easier.
Retired Moderator
The do-it-yourselfers I know have had good results, however they all preach : Prep Work is most important to produce good results
Thanks dark water i like to save money whenever i can and that usually means doing things myself. Its ok working on my heep is fun [but sometimes frustrating]. I used durabak in comes in a few different colors but i just used black. It helps if you sand the area with some high grit sandpaper before you put it on. I used like 250 i think.....Then wash it all out and roll on the liner. With the durabak and probably most other liners it came ready to go. All i had to do was open the lid and roll it on. Dont have to add or mix anything with it. Ill get pics asap
the pics look great I will be doing the durabak this weekend
1 - 13 of 13 Posts
