So my 87 4 banger needs new spring bushings on shackle side...my leafs and shackles are not
stock and wondering if they would use the same bushings....would like to order the right ones the first time! Thanks
What springs are they? I have a new set of BDS bushings for sale. I put them on to drive the Jeep home, then took them off right away. Most people like poly bushings, I prefer rubber and swapped mine.
Send me a PM if you're interested.
Thats the problim...P.O. installed springs and cant read any numbers on them....just wondering if all"YJ" bushings were the same diameter??
No, they aren't the same. I went through 6 different sets of bushings before I found the correct ones to fit. Each manufacturer has their own size of eyelet in the end of the springs it seems.
After the 5th set of wrong bushings I used an internal micrometer and measured the eyelet of the spring, then ordered that size from Morris.
