Today changed the oil and differential fluids, washed waxed ( don't judge its my DD ) and pulled doors and greased door pins. I used regular wheel bearing grease, last time I used never seize. Had a problem with the rear doors coming off hard. lightly sanded the pins and cleaned the hinge holes out.
Question is what is the best lube for the door hinge pins ???
Thought the never seize would do it ! :pullinghair:
