I have a 97 2.5 with a 5 speed. It was totaled about 8 years ago and has been sitting until I got it a year ago. I swapped the body with a YJ but kept the OBD2 system in it. I got it running again about 4 months ago.
Every since I got it back running about 3/4 of the times I start it and start driving about 1-2 mins it will sputter and major loss in power. I can mash the clutch in and give it gas about 3-4 times it will clear up and driver great the rest of the time.
I have replaces the plugs, wires, cap, button, coil, temp sender, timing chain and guides, intake and exhaust gaskets, fuel pump, cleaned the tank and throttle body.
I do have aftermarket gauges but the temp sender is still feeding to computer. The oil and fuel senders are not feeding the comp. Every thing I have read says the comp only monitors the oil pressure and it does not effect the running of the engine.
All your help with this will be appreciated.
Knows a couple things...
The time that happened to my TJ, it proved to be a bad/weak fuel pump. I would replace it with either a Mopar or a Bosch fuel pump. Avoid Spectra and Airtex fuel pumps, their quality is not worth installing. I would also avoid store brands from stores like AutoZone.
