I have an intermittent squeak under the hood that may be coming from the belt. It only happens under certain conditions but I'd like to remedy before I get stranded somewhere.
The belt looks fine, has good tension, but on the fan pulley I see some chunks of rubber stuck to it, like it was burned on.
Has anayone experienced this?
Any advice is appreciated.
Ps. I have an '06 X with 4.0L 6 cyl.
I sprayed water on mine and it would shut up for just a couple seconds. That told me it was the belt. Then, six months later it happened to start squeeking again. I sprayed water on the belt and it did not make a difference in the noise. I shut it off then sprayed a little white lithium grease inside the shaft of the alternator (no change when started back up) then in the shaft of the water pump (and it quieted for a second) told me the water pump bearings were going bad. We replaced the water pump and since then, I went from an Avg. of 200 degrees down to Avg. 185 never going over 190.
If you spray or trickle some water on the belt, it should change the noise if it is the belt...
