1 - 9 of 9 Posts
My 06 lj is squeaking from the rear. It should like the rear right breaks. The breaks are making noises while I idle forward, and when I accelerate it squeaks really bad, when I stop accelerating the squeaks goes away. I replaced the rear pads, and driver side rotor and caliper. The breaks still drag a little when spin the tire when it's on the lift.
Hit the brakes when accelerating and see if the noise goes away.
Kinda like ride the brakes.
If it does then its the pads.
If it doesn't then check something else
Yea so I pulls the drive shaft and it's one of the u joints. Should I just get 2 u joints from napa, or should I grease these, and order stronger ones. Also can I drive in 4wd drive on the road with just the front drive shaft. I know your not supposed to, but can I drive to napa and back like that, or should I put the rear back in and go 2wd.
1 - 9 of 9 Posts
