My steering wheel has started to squeak when turning it around. I'll take the dash panels off one of these days to see if I can find what's wrong, but I figured I would check here to see if this happens often to other TJ's
Knows a couple things...
That is a common problem that is easily fixed. Spray the steering wheel shaft where it passes through the rubber grommet on the fire wall with white lithium grease.
AzTJ said:
It becomes more noisy as winter sets in. :D The noise usually goes away after the engine is warmed up and warms up the rubber grommet.
That's true, it does go away. But I sprayed some grease at it and fixed it.
Cool! Gotta love forums. Most any issue you have, others have and have solved!
