Hey, I'm just look for some ideas what this squeak might be. I usually hear it windows down after the jeep has been sitting for a little. I'll drive off and start hearing the squeaks, from the rear half of the jeep. I have a suspicion it maybe the wheel bearings, but could it also be the rear brakes? The sound goes away after a 10 secs or so, Any ideas would be cool!
Does the time between squeaks decrease as you speed up so you are hearing it faster and faster? Could possibly be the rear U joints if that's the case.
Year/model? Discs/Drums?
If it was a u joint it would clunk and in the rear you wouldn't really be able to drive it at all. Squeeking is usually brakes.
I've have am 03 sahara tj with rear disc brakes and a 2" lift, the squeaking only happens after its sat for a while. And it happens when I initially drive it for about 10 seconds and it goes away
See if you can recreate the squeak by just rocking the tub side to side.
While I have chased several squeaks of the last several years, the tricky one I finally solved (similar to yours) was all I needed to was retorque my trackbar bolts...a bolt was barely loose causing the bushing to squeak. It could also be control arm bushing or a loose body mount.
A rotational squeak (consistent with the tires rolling), can be a bad ujoint or worn brakes.
