Having only a leveling kit on my 17 jk Willys, I'm loooking for SS brake lines and only seem to find ones for 4-6" lift. Would the longer ones work or would they be too long?
Those will work. They will loop outwards a bit to make the slack, but they looks awesome and function even better eliminating that troublespot crimp.
Longer lines will work fine. You will just need to fully compress each corner/wheel of the Jeep in order to insure that the line isn't getting pinched in anything. Loose zip tie loops, where needed, can direct the lines along a desired path.
Oem brake lines that come on a 2017 jk are very good brake lines and plenty long even for a 3.5 lift. I installed a metal cloak 3.5 on my buddy’s jeep and oem brake lines were as long as the mc brake lines. So unless you are just after looks i would keep them. I personally would not want extra long lines if i just had a leveling kit or even a 2.5 lift.
