1 - 1 of 1 Posts
Trying to get an engine swap going. At this point I can jump out the starter relay and the engine will turn over. When I turn the key to the start position I have 12 volts going to 1 terminal at the relay and 8 volts on the other side? Shouldnt one side go to ground? Looking at the wiring diagram the terminal that has 8 volts (black w/ white stripe) goes back to the engine controller
1 - 1 of 1 Posts
