OK, the jeep was running fine and I parked it and came back and no effort from the starter. I have checked the battery and have 12.2-12.4 volts. I have checked the hot wire at the battery and have the same voltage. When I try and start the jeep the voltage drops down to around 11.7 volts. I have checked the ignition wire at the starter and it also has 11.7 volts. Everything I am seeing is pointing towards the starter, but I have never had one just quit instantly and not show any signs of going bad until then. I also checked from the positive battery terminal to the outside of the starter and it show 12.4 so I know the ground is good.......
any ideas? Have you guys seen a starter do this?
