Starter ?????
615 5
Hey guys, I was wondering if anyone can tell me how to tell that a Starter is going out. Because it seems its taking a little longer for it to start.
2006 LJ Rubi 6spd
It will get where it drags bad when you go to crank it. It's kind of hard to explain without hearing it. What exactly is yours doing to make you think it's going out?
It's still working but just seems to take alittle longer sometimes to start, but as far as the battery goes its about 1-2yr old duralast that the last owner put in it. Also it doesn't seem to be making any funny sounds.
I'm also in the process of changing the plugs out, but when I put the new ones in and put everthing back together it wouldn't even run. So I then took everything back apart and put the orginal plugs that have 90,000 on them back in and it started right back up, so I figure later today I would go and change the plugs back around and see if they work.
