Any suggestions on rear drive shaft to connect a np 241 w/ a S.Y.E to my rear axle? cheapest solution would be much appreciated, cuz i have to keep my D35 in the rear for a short time. im getting a ford 8.8 but i have to lay low on the spending. my wife is going berzerk. here's a run down of the $$$ i pissed away...350 motor: $2,500.00(i built to keep cheap) TH400:$950.00 (i built from bone yard)Transfer case np 241 S.Y.E $500.00. And when im done typing this im going online to Jegs and dropping another $1,700.00 in exhaust- cooling- serp. pully system, blah, blah. so you see, i NEED a cheap solution.
Drives by Braille
Check locally. I'm sure there are some decent driveline shops that can make you a custom shaft.... if not, Tom Woods makes good ones on the cheap.
