I'm a old school SBC guy, this new stuff sucks. I have a 98 TJ 2.5 liter 5 speed. Been running fine until I left for lunch today. Started up and died instantly. Turned over a few times and nothing. I gave it a little gas and it fired right up, idled down real low, then came right back up to about 700 rpms. Runs smooth after that. Every single time you shut it off, you either have to give it gas to start it, or turn it over about 10 times. Fuel pump kicks on instantly, fuel rail when turned off for an hour still squirts gas out about 4 inches, when running all the way to the fender almost. Though it might be the check valve bleeding back, but if you kill it and start it back less than 3 seconds later, same issue. Any idea's? Maybe the throttle position sensor?
Battery tested good under load, battery cables and ends are tight, clean, and less than 1 month old.
Yeah, being as you are seeing fuel pressure on the rail after it sits for a good while I'd lean towards either TPS or IAC. Usually an easy way to check to see if the IAC is bad, if you have A/C, at idle kick the A/C on, if the engine RPM drops then the IAC is probably bad. If the idle stays the same or drops for a split second then recovers to normal speed then possibly the TPS. Of course there are a lot of other things that can cause your symptoms, but those are where I'd start looking.
Def sounds like an Idle Air Control Valve issue (IAC). The IAC is what allows air into the engine to keep it running when the throttle plate is closed. The IAC meters the amount of air entering the engine. These valves do go bad but they can usually be removed & cleaned with carb cleaner as a temp fix.
Yeah, it depends on the position of the IAC pintle when it failed, being as they really only affect things at start up cold and when the engine load changes, as in turning on the AC compressor, they usually fail and stick in a position where it'll run fine once started and warmed a few seconds. I still lean towards the IAC.
