I have the Rancho 2” lift and lower control arms. Finally got a set of JKS quicker disconnects. Clearly the sway bar has been working just fine with the current disconnects but I know they are too short. Can someone send out a pic of the right sway bar angle or give me an idea of how long these should be compared to the stock sway bar connects?
Am I correct in thinking an alignment will not be necessary after install?
10-15* angled up yes no alignment needed as won’t have any effect on that.
They should be similar to length as your stock rear sway bar links as most kits replace teh rears with longer ones and move the rears to the front
Vendor
Just a heads up the front shock will be your next "limiting" factor.
You will need either a longer shock.
A lower shock bracket for more travel
And make sure the drive shaft and exhaust are good too.
Thanks Matt
No alignment needed. A proper sway bar angle is about 10° above level on the front sway bar. But anything from about 5° to 10° above horizontal will work very well.
Discussion Starter #6
Thanks Matt
Wait, I bought your lift package, with shocks, springs, and lower control arms. You’re telling me my shocks are too short?
