I have a 2004 tj. I started it today no problem, tried to start it again and nothing. I tried a couple of times and nothing. I took the key out of the ignition and all the gauges started going back and forth like windshield wipers. Has anybody had this happen? I think it could be in the ignition switch? Any thoughts?
Turn the key on/off a few times without engaging the starter to display any problem codes on the odometer. If none, disconnect the negative battery terminal to reset it.
