So it doesn't matter what speed it is but when I turn left my steering binds up for a quick second which can be sketchy at high speeds, I have a 2in bl steering bracket on it but I dropped my bl down to a 1.25. What would cause this would it be the bracket? Or something else?
Thanks
I had a binding issue caused by damage to the lower steering shaft bearing. Lifted the body off the frame for some work, the upper shaft was rusted and did not telescope so it pulled on the lower shaft and damaged the bearing.
Sent from my SM-G955U using Tapatalk
