Ok.. Thanks a lot for the detailed response, I really appreciate it..On top of the steering box you should find an Allen bolt sticking out with a nut around it. Put your Allen wrench in the Allen bolt and hold it still while you loosen the nut, then hold the nut still while you adjust your steering wheel play by screwing in the Allen bolt until the slop is gone. Don't forget to test drive it because you may find you have gone a bit too far and the steering wheel may feel like it is binding a bit. If it's binding, back the Allen bolt back out just a hair and try again. Continue to adjust to your desired play. When you are satisfied, hold the Allen bolt still and tighten up the nut around it to lock your adjustment Allen bolt in place. This is hands down the cheapest fix I've done that fixed a big issue. Hope this helps! You can also YouTube this to see what exactly is happening inside the box as you turn that adjustment Allen bolt and understand how your steering works.
sure thing manOk.. Thanks a lot for the detailed response, I really appreciate it..
So what would you recommend ??Actually, that's not correct. That adjuster is actually the pitman shaft overcenter torque adjustment screw. Its not there to adjust out the slop of worn steering components. Tightening it till it "fixes" your loose steering will accelerate wear and give you improper steering feel/feedback. Its such a popular myth, though, that I cant convince the masses that believe in it. Its main attractiveness is that its right there in front of you and you don't even have to lay on your back with a helper and get all greasy. Just wanted to let you guys know. Carry on.
Did you do what I recommended in the second post above?So what would you recommend ??
My pitman arm bolt had worked itself loose.. Couldn't tell it by looking at it but I was checking everything and realized it was loose. Works like a new one now! Thanks for all the replies!Did you do what I recommended in the second post above?
Adjusting the steering box is a hit or miss short time fix for steering box play.So what would you recommend ??
Good find.My pitman arm bolt had worked itself loose.. Couldn't tell it by looking at it but I was checking everything and realized it was loose. Works like a new one now! Thanks for all the replies!
I've seen some other threads on the Durango box swap - What are the advantages (and disadvantages) of the Durango box over the stock YJ box?Adjusting the steering box is a hit or miss short time fix for steering box play.
Replacement with a new or quality rebuilt box is the only permanent cure.
Used steering boxes are not an option unless you know the history of the part because the odds are with a 20 year old vehicle its worn out too.
The Dodge Durango upgrade is an excellent option because of its advantages and can be done for less than $150. Your safety is worth that.
I did it to mine and don't regret it.
I guessing you did the swap? Is it a pretty straight forward swap!I noticed a quicker turn ratio and less effort with my 32x12.50x15 tires. If you want to call it a disadvantage you loose one mounting bolt on the steering box but it is still mounted very solid , if its good for a 5000# Durango it should be OK for a 3800# Jeep.
It is as simple as a straight steering box replacement. The only thing I didn't have to deal with is removing the pitman arm because I installed a new one.I guessing you did the swap? Is it a pretty straight forward swap!
