I purchased and install 15x8 crager soft 8's on 33x12.50 bfg km2 at work the other day and I was wondering who has upgraded their steering with 15's on the jk. What heim or tie rod ends did you use to clear the rims?
Yeah I was wondering if I could just make a larger round tie rod and drag link and keep the stock ends. Sounds like it defeats the purpose though if I do that
RK's older tie rod used stock ends. As mentioned in another thread. The Steer smarts tie rod does not rotate like Synergy's. The rotation of the tie rod and larger Synergy joints rubbed my wheel (15's)
Somebody else ground the corners of the Synergy joints to clear the wheel.
