So my steering has been acting real weird lately. When I turn the wheel sharply(anything past a 3/4ish rotation) the steering wheel kicks back and forth like my tires are bouncing off rocks and i lose a lot of power to the wheels (I can’t roll over flat ground without giving it a good bit of gas). Also when it is turned there are popping/ knocking noises from the transfer case area/ tail end of the Jeep. I’m thinking it’s some of the power steering stuff but I was wondering if something with the transfer case could mess with my steering. My linkage is very off after an off-road trip and this problem started at around the same time. I haven’t gotten around to fixing it yet because i figured it’s just stopping me from shifting into 4wd which isn’t an urgent problem.
As you can see the bolt holding the linkage in in this picture I have that completely missing from mine? Assuming it just fell out. And ideas if this could be my problem? Thanks.
1998 4.0 Sahara automatic.
You are stuck IN 4wd...
Yes that is your problem
Adjust the t-case linkage you are stuck in 4wd and don't drive it until you get it out of 4wd. You'll be buying a transfer case soon if you don't.
