Steering Question
1348 Views 9 Replies 6 Participants Last post by  Texasjk
2
Would I be better off with a stock pitman arm with my setup? It’s currently a dropped arm. I’ve been getting death wobble, so I was wondering if running a stock pitman arm and lowering my track bar on the passenger side would possibly fix some of the issues.
4440155
4440156
1 - 10 of 10 Posts
View attachment 4440155 View attachment 4440156
Tell us more... What lift kit? How many miles? What has been checked and/or replaced so far? What is caster at?
As a rule, a drop pitman arm is a bad way to correct steering geometry. A better way is a drag link flip and raised track bar bracket. Whatever you do, it is key that the track bar and drag link are parallel.
But a drop pitman arm should not cause death wobble.
It’s a crappy rough country lift (hence the drop arm), 72000 miles, drag link was replaced about 10000 miles ago, track bar replaced a few hundred miles ago, tie rod is stock with a new one in the mail, caster is 5 degrees with 1-2 degrees of pinion angle.
Thanks!
Yeah the drop pitman arm was installed with a crappy rough country kit by a shop awhile back. Didn’t know much then, but I know a lot more now! I was told by a local shop that it’d be a good idea to order one, so I was just looking for some more opinions.
The drop pitman arm puts more load on the bearings in the steering box. So I would replace it with either a stock setup or a flipped drag link / track bar bracket.
Death wobble is typically caused by play in the front end linkages and/ or ball joints. There is an excellent video set by planman that pretty thoroughly covers it. I would link you to the videos but I am on my phone out at an off road park in PA.
Reactions: 1
I just went through the death wobble.it turned to be my ball joints.I changed my entire steering and it turned out to be the ball joints.
1 - 10 of 10 Posts
