looking to mount the steering stabilizer up out of harms way on my 13 jk and i saw that the poly flip kit requires +2" of bump stop
anyone know of a stabilizer relocate bracket or kit that will work without damaging anything on an otherwise stock 13 2d jkr?
I know I tried to use the JKS relocation bracket on stock and there is not enough room. So I will have to wait until I lift it.
Rough Country Relocation Bracket # 1108. Used this on my stock suspension '13 Rubicon and it works with no problems. I kept the stock tie rod shock mount for the other end and just rotated it around to a position that works. Everything clears. The relocation bracket is only $20 and works with the stock stabilizer shock on a '13.
The attached picture shows the stabilizer in it's relocated position. Couldn't get a good picture of the bracket itself up in there but this gives you a idea of what it does and the repositioned stock bracket for the tierod end of the shock.
just what i was looking for thank you sir :)
