1 - 20 of 21 Posts
Went wheeling disco front and kept hearing a popping noise. Kept looking under to see any parts hanging, broken, whatever could be making that noise. Nothing. Got home, cleaned her up, and saw this. How do I correct this issue? Did I bend something on a rock? Would a simple alignment do the trick?
Bicycle tire Automotive tire Bicycle frame Tire Bicycle fork
Wheel Tire Bicycle tire Automotive tire Automotive lighting
Automotive tire Musical instrument Wrench Bumper Automotive exterior
To prevent bump steer a line drawn thru ends of drag link has to be parallel to a line drawn thru ends of the control arm
So with just a lift they stay parallel but if you drop the non axle end of one you must also drop the non axle end of other
Otherwise as axle goes up and down wheels turn to left or right which is a bad thing called bump steer
Discussion Starter · #12 ·
Bump steer was bad before I put the RC stabilizer on. Since I did that, she drives fine. My only complaint is the popping noise coming from the stabilizer banging the trackbar when its flexing. (@ least thats what I believe the noise is from)
Discussion Starter · #15 ·
Death wobble is different than bump steer
Now your making think I know even less than I thought I knew. Before the stabilizer was upgraded from the oem if I hit a pot hole, went over a bridge, hit a rough spot in the road, the jeep would take off suddenly going down the road and I'd have to correct the steering to keep it in the road. Thats bump steer. The death wobble is more severe going down the road constantly. What am I getting wrong?
A stabilizer is not a fix for bump steer which is a geometry of track bar and drag link problem
A stabilizer is a poor bandage fix for death wobble
See the video I posted it is all about geometry for bump steer
A shock absorber can dampen a spring oscillation it cannot do anything to steering geometry of Solid steel rods that have no spring vibration to dampen
If the drag link displaces its end a different amount than the track bar end does as axles moves up and down the wheels must move left or right and a steering damper cannot change that
x2 with Digger, he's spot on.
if your front end is set up correctly you can remove the stabilizer and notice minimal differences.
the drop pitman arm was a thing in leaf sprung vehicles that were lifted but are almost always a bad idea for TJ's and most coil and link suspensions.
Discussion Starter · #19 ·
I appreciate the input. Would an alignment shop have knowledge of these issues or should i go ahead and order the parts, and tell them what needs to be done?
1 - 20 of 21 Posts
