2004 Wrangler TJ with 42RLE auto trans. F/R lockers, 5.38 gears, Warn Winch, Currie 4" Suspension
The Crown HD kit is nothing but a Grand Cherokee ZJ tie rod, it uses the same drag link you currently have installed. You could get the same strength upgrade for less $$$ by just replacing your TJ tie rod with a ZJ tie rod.
