My steering wheel is a little off center and i am trying to adjust it back to center. I have found threads explaining this and it seems simple but i dont have the stock drag link any longer and cant simply adjust the bracket by loosening the bolts and turning the drag link. I am running the currie currectlync system and cant find anything in regards to this system. any help would be appreciated.
Doesn't the whole bar turn after loosening the jam nuts ?
good question, i have not tried this yet. i have been searching for a solution and didnt even think of this. so if the bar will turn after i loosen the jam nuts it would do the same as adjusting the clamp on a stock drag link?
Discussion Starter #7
I would just call Currie Enterprises and ask them.
714-528-6957
Thanks for the info :thumb:
That's ok .. I just looked at the Currie drag link.
Once the jam nuts are loose, the bar rotates just like the stock turnbuckle :thumb:
Awesome! Thanks for the clarification, i will do this tonight when i get off work.
