1 - 20 of 28 Posts
2005 Wrangler LJ, 2 1/2" OME lift, 1 1/2" spacer in the front, Rancho shocks, 1" Body lift, 33"s
Just bought my son a 2008 Wrangler 2dr., It has a 3.5" spring lift and 315/70R17 BFG's on it. It has a slight wobbling feeling in the steering wheel at around 25 to 30 mph. You can let go of the wheel and see it moving back and forth, left to right. It goes away on it's own if you speed up or slow down? Anybody ever hear of anything like this?
Reactions: elithrash
I have the same thing but at like 40-45 mph. Maybe unbalanced tires or bent rim? If you figure it out can you please let us know what was causing it for you?
Very likely unbalanced tires, but could be loose bolt. Start by re-torqueing your LCAs, UCAs, tie rod, drag link and track bar. If it still wobbles try rotating your front tires to the back.
Definitely not death wobble. DW is a violent shaking of the front end and steering wheel around 45 mph that only stops when you stop the Jeep. It's one of these "you'll know it when you see it" things.
Your issue might be an out of balance tire; can also be caused by a dented rim or some mud in the wheel.
Your alignment might also be off. I had such shake recently, that all but went away when I realigned.
Reactions: cflo
Any wobble (tire people refer to it as a shimmy) that is speed sensitive as both SuperDad and elithrash have described is almost always wheel/tire related.
Death Wobble (aka DW) is characterized as occurring suddenly at any speed can only be stopped by coming to an almost complete stop. While covered extensively on Jeep forums, DW is something that can occur on any vehicle with a solid front axle and coil spring suspension on that axle. It is usually enabled by a loose suspension joint, most often on the track bar that allows the front axle to move slightly and set up that movement in a harmonic.
When I first purchased my TJ in 2014, I had the same questions about DW and found this post very helpful. Along with others, I usually provide a link so new members can understand our Jeep suspension. It takes some time as it is lengthy along with two 20 minute videos, but after reading it, I had a better understanding of our suspension.
http://www.wranglerforum.com/f202/d...fixing-non-dw-shimmies-and-wobbles-78034.html
Reactions: JeepRocks
I get this from time to time. I will get a build up of mud on the inside of the wheel. Might not be a bad idea to check.
I'll first try and get them rotated and balanced
@SuperDad, make sure you specifically ask them to road force balance with large tires.
Reactions: SuperDad
Mine did this was between 45-50mph...
Turned out the tires were separating... both fronts and one rear.
So, if they have not thrown a balance weight, look them over real good.
Sounds typical of BFG tires over the past few years. Probably a defect in one or both of the tires up front.
There is a chance the steering box needs tightened up a bit. I had that once. Your alignment guy should be able to do that. It needs to be done right or further damage could happen in the future.
I had one a while back with a slight wobble and after resurfacing the front brake rotors it went away. You may want to check rotors with a run out gauge to see if they need attention, that is easy to do while you have the tires off
Hey Super Dad, congrats on getting your mini-me a nice Jeep starter kit. My first was also a 2dr (TJ) and I'll never forget it.
Ok, your big clue is the bent tie rod. Tie rods can take a lot of punishment so the previous owner likely was off roading and hit a large rock with their tire. Bent tie rods are usually not a big deal. That said, I agree with the gentlemen who said to look at your front suspension (especially rgreen65). Look for anything from loose bolts to other things that also got whacked or dented. When I had Death Wobble in my TJ, it was caused by very worn ball joints. It can also be caused by broken or worn component ends, like tie rod bushings, control arm bushings, etc.
How to quick check: If you have a street jack, get the front wheels off the ground, use jack stands, then just grab and jerk on every joint you see in the front. If anything moves *at all* at the joint or mounting point at the end, that's likely a problem and needs to be fixed. Ball joints can be tested by putting a tire iron under the wheel and trying to pry up or just pull the top of the wheel back and forth hard when it's off the ground. *Any* play or clicking is a problem (bad ball joints, wheel bearings, etc).
Some of the references given in this thread are excellent for finding DW (kudos to rgreen65 :thumb:).
obtw, I suppose it's possible, but I've never heard of a professional shop doing an alignment with a bent tie rod. That should change the geometry of the whole front and make the alignment less reliable.
Definition of DW - not speed sensitive (doesn't stop if you speed up of slow down), usually happens when you hit a bump/pothole in the road and is always violent - no doubt it's death wobble. (OMG, I'm gonna die unless I stop NOW!)
Good luck.
Discussion Starter · #16 ·
Ok, so it's not the tires. I had the balance check on them and they are all good. Will start looking at tie rods and other front end parts tonight.
Discussion Starter · #17 ·
Took it to a shop and put it on a lift. Front end parts all seem good and tight, no sign on bent tie rods ether.
I ended up buying some Rancho RS62103 Geometry Correction Brackets. Going to have the shop put them on and see how it drives.
Discussion Starter · #19 ·
I had the same problem - I removed the wheel spacers from the front wheels and the problem went totally away.
I don't have wheel spacers
I did Napa's offset upper ball joints on the top and Moog ball joints on the bottom. Those have micro grease zerks on the sides, not the top of the joint so check them first, then you can grease them. Your alignment guy will do a reading and tell you what offset he wants for each side. Every Jeep is different.Then put a good set of adjustable heavy lower control arms on. Factory arms are too soft. Core 4x4 are great. After your done your alignment guy will do a final alignment. That fixed all 3 of my Jeeps.
1 - 20 of 28 Posts
